How to bring together fault tolerance and data consistency to enable grid data sharing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
This paper addresses the challenge of transparent data sharing within computing grids built as cluster federations. On such platforms, the availability of storage resources may change in a dynamic way, often due to hardware failures. We focus on the problem of handling the consistency of replicated data in the presence of failures. We propose a software architecture which decouples consistency management from fault tolerance management. We illustrate this architecture with a case study showing how to design a consistency protocol using fault-tolerant building blocks. As a proof of concept, we describe a prototype implementation of this protocol within JuxMem , a software experimental platform for grid data sharing, and we report on a preliminary experimental evaluation of the proposed approach.
Autre [cs.OH]
RR-5467.pdf (339.66 Ko) Télécharger le fichier
inria-00070540 , version 1 (19-05-2006)
  • HAL Id : inria-00070540 , version 1
Gabriel Antoniu, Jean-François Deverge, Sébastien Monnet. How to bring together fault tolerance and data consistency to enable grid data sharing. [Research Report] RR-5467, INRIA. 2005, pp.32. ⟨inria-00070540⟩
272 Consultations
158 Téléchargements
