Learning Surfaces by Probing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Leonidas J. Guibas
  • Fonction : Auteur
Steve Oudot
  • Fonction : Auteur
We consider the problem of discovering a smooth unknown surface S bounding an object O in R^3. The discovery process consists of moving a point probing device in the free space around O so that it repeatedly comes in contact with S. We propose a probing strategy for generating a sequence of surface samples on S from which a triangulated surface can be generated which approximates S within any desired accuracy. We bound the number of probes and the number of elementary moves of the probing device. Our solution is an extension of previous work on Delaunay refinement techniques for surface meshing. The approximating surface we generate enjoys the many nice properties of the meshes obtained by those techniques, e.g. exact topological type, nomal approximation, etc.
RR-5434.pdf (2.18 Mo) Télécharger le fichier
inria-00070573 , version 1 (19-05-2006)
  • HAL Id : inria-00070573 , version 1
Jean-Daniel Boissonnat, Leonidas J. Guibas, Steve Oudot. Learning Surfaces by Probing. RR-5434, INRIA. 2004, pp.21. ⟨inria-00070573⟩
101 Consultations
98 Téléchargements
