Multicast routing with QoS based on incomplete link state information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
This paper is concerned with developing novel algorithms for multicast routing in packet switched communication networks when there is no available exact information about the link states in the network. In these cases probabilistic models can be used and the goal of the route selection procedure is to find an admissible route with maximal probability. The multicast probabilistic routing model with bandwidth and cost requirement in the case of incomplete information is reduced to a deterministic Steiner tree problem. The multicast routing concerning the end-to-end delay requirement can be transformed in some cases to finding shortest paths between the multicast nodes based on equivalent deterministic link measures.
Autre [cs.OH]
RR-5428.pdf (666.41 Ko) Télécharger le fichier
inria-00070579 , version 1 (19-05-2006)
  • HAL Id : inria-00070579 , version 1
Miklos Molnar, János Levendovszky, Patrice Leguesdron, Csaba Végsö. Multicast routing with QoS based on incomplete link state information. [Research Report] RR-5428, INRIA. 2004, pp.21. ⟨inria-00070579⟩
317 Consultations
105 Téléchargements
