PARA++ : C++ Bindings for Message Passing Libraries : User Guide - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1995
The aim of Para++ is to provide a user-level C++ interface to message passing libraries, by encapsulating the notions of processes and inter-processes communications into specific C++ objects and streams. Actually, this abstraction level allows to implement Para++ with any kind of message passing library. Para++'s main idea is to add new C++ io-streams to allows inter-tasks communications. These streams support all generic scalar datatype ({\tt int}, {\tt float}, {\tt double},...), plus some mathematical datatypes ({\tt Vectors}, {\tt Matrix},...) in order to exchange data between co-operating tasks. Para++ has been implemented on top of PVM and MPI.
Mots clés
Autre [cs.OH]
RT-0174.pdf (257.6 Ko) Télécharger le fichier
inria-00071200 , version 1 (23-05-2006)
  • HAL Id : inria-00071200 , version 1
Olivier Coulaud, Eric Dillon. PARA++ : C++ Bindings for Message Passing Libraries : User Guide. [Technical Report] RT-0174, INRIA. 1995, pp.26. ⟨inria-00071200⟩
194 Consultations
344 Téléchargements
