Drawing $K_n$ in Three Dimensions with One Bend per Edge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We give a drawing of $K_n$ in three dimensions in which vertices are placed at integer grid points and edges are drawn crossing-free with at most one bend per edge in a volume bounded by $O(n^2.5)$.
RR-5708.pdf (158.92 Ko) Télécharger le fichier
inria-00071219 , version 1 (23-05-2006)
  • HAL Id : inria-00071219 , version 1
Olivier Devillers, Hazel Everett, Sylvain Lazard, Maria Pentcheva, Stephen Wismath. Drawing $K_n$ in Three Dimensions with One Bend per Edge. [Research Report] RR-5708, INRIA. 2005. ⟨inria-00071219⟩
244 Consultations
185 Téléchargements
