GDS: an Architecture Proposal for a Grid Data-Sharing Service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Grid computing has recently emerged as a response to the growing demand for resources (processing power, storage, etc.) exhibited by scientific applications. We address the challenge of sharing large amounts of data on such infrastructures, typically consisting of a federation of node clusters. We claim that storing, accessing, updating and sharing such data should be considered by applications as an external service. We propose an architecture for such a service, whose goal is to provide transparent access to mutable data, while enhancing data persistence and consistency despite node disconnections or failures. Our approach leverages on weaving together previous results in the areas of distributed shared memory systems, peer-to-peer systems, and fault-tolerant systems.
RR-5593.pdf (191.23 Ko) Télécharger le fichier
inria-00071239 , version 1 (23-05-2006)
  • HAL Id : inria-00071239 , version 1
Gabriel Antoniu, Marin Bertier, Luc Bougé, Eddy Caron, Frédéric Desprez, et al.. GDS: an Architecture Proposal for a Grid Data-Sharing Service. [Research Report] RR-5593, INRIA. 2005. ⟨inria-00071239⟩
783 Consultations
371 Téléchargements
