Index routing for task allocation in Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Bruno Gaujal
In this paper we show how index routing policies can be used in practice for task allocation in computational grids. We provide a fast algorithm which can be used off-line or even on-line to compute the index tables. We also report numerous simulations providing numerical evidence of the great efficiency of our index routing policy as well as its robustness with respect to parameter changes.
Autre [cs.OH]
RR-5892.pdf (223.94 Ko) Télécharger le fichier
inria-00071376 , version 1 (23-05-2006)
  • HAL Id : inria-00071376 , version 1
Vandy Berten, Bruno Gaujal. Index routing for task allocation in Grids. [Research Report] RR-5892, INRIA. 2006. ⟨inria-00071376⟩
68 Consultations
182 Téléchargements
