Genetic genealogical models in rare event analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We present in this article a genetic type interacting particle systems algorithm and a genealogical model for estimating a class of rare events arising in physics and network analysis. We represent the distribution of a Markov process hitting a rare target in terms of a Feynman-Kac model in path space. We show how these branching particle models described in previous works can be used to estimate the probability of the corresponding rare events as well as the distribution of the process in this regime.
RR-5878.pdf (337.12 Ko) Télécharger le fichier
inria-00071391 , version 1 (23-05-2006)
  • HAL Id : inria-00071391 , version 1
Frédéric Cérou, Pierre del Moral, François Le Gland, Pascal Lezaud. Genetic genealogical models in rare event analysis. [Research Report] RR-5878, INRIA. 2006. ⟨inria-00071391⟩
301 Consultations
221 Téléchargements
