Implementation and Complexity of the Lowest Static Reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Bernard Paul Serpette
  • Fonction : Auteur
Szabolcs Szentes
  • Fonction : Auteur
The lowest static reduction (LSR) is the 0^th-order Control-Flow Analysis without continuation passing style (CPS) consideration. This article presents some algorithms resolving LSR and their related complexities. Even if this analysis is generally declared to be computable in cubic time, a stand alone algorithm reaching this complexity is not so straightforward. With the -calculus as input language, we will start with a blind algorithm and step by step we will finally exhibit the algorithm which run, for worst cases, in cubic time related to the size of the program.
Autre [cs.OH]
RR-5034.pdf (263.5 Ko) Télécharger le fichier
inria-00071550 , version 1 (23-05-2006)
  • HAL Id : inria-00071550 , version 1
Ludovic Henrio, Bernard Paul Serpette, Szabolcs Szentes. Implementation and Complexity of the Lowest Static Reduction. RR-5034, INRIA. 2003. ⟨inria-00071550⟩
148 Consultations
94 Téléchargements
