Reachability Analysis over Term Rewriting Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
This paper surveys some techniques and tools for achieving reachability analysis over term rewriting systems. The core of those techniques is a generic tree automata completion algorithm used to compute in an exact or approximated way the set of descendants (or reachable terms). This algorithm has been implemented in the Timbuk tool. Furthermore, we show that classes with regular sets of descendants of the literature corresponds to specific instances of the tree automata completion algorithm and can thus be efficiently computed by Timbuk. An extension of the completion algorithm to conditional term rewriting systems and some applications are also presented.
Autre [cs.OH]
RR-4970.pdf (435.78 Ko) Télécharger le fichier
inria-00071609 , version 1 (23-05-2006)
  • HAL Id : inria-00071609 , version 1
Guillaume Feuillade, Thomas Genet, Valérie Viet Triem Tong. Reachability Analysis over Term Rewriting Systems. [Research Report] RR-4970, INRIA. 2003. ⟨inria-00071609⟩
145 Consultations
347 Téléchargements
