Analogy on Sequences : a Definition and an Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Laurent Miclet
  • Fonction : Auteur
  • PersonId : 833455
Arnaud Delhay
We present a definition of analogy on sequences which is based on two principles : the definition of an analogy between the letters of an alphabet and the use of the edit distance between sequences. Our definition generalizes the algorithm given by Lepage and is compatible with another definition of analogy in sequences given by Yvon.
Autre [cs.OH]
RR-4969.pdf (260.43 Ko) Télécharger le fichier
inria-00071610 , version 1 (23-05-2006)
  • HAL Id : inria-00071610 , version 1
Laurent Miclet, Arnaud Delhay. Analogy on Sequences : a Definition and an Algorithm. [Research Report] RR-4969, INRIA. 2003. ⟨inria-00071610⟩
115 Consultations
1361 Téléchargements
