A condition for isotopic approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Frédéric Chazal
David Cohen-Steiner
  • Fonction : Auteur
  • PersonId : 833472
In this note, we show that if two surfaces in are homeomorphic, then a simple and purely topological condition is sufficient to ensure the existence of an isotopy between them. When the surfaces are connected, the condition is merely that one surface is contained in some topological thickening of the other and separates the two boundary components of that thickening. The proof of this result is based on basic 3-manifold topology.
Autre [cs.OH]
RR-4931.pdf (86.36 Ko) Télécharger le fichier
inria-00071648 , version 1 (23-05-2006)
  • HAL Id : inria-00071648 , version 1
Frédéric Chazal, David Cohen-Steiner. A condition for isotopic approximation. RR-4931, INRIA. 2003. ⟨inria-00071648⟩
95 Consultations
164 Téléchargements
