A Note on the TCP Fluid Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
In this paper, we revisit the fluid TCP model and propose an explicit solution of the non-linear differential equation. We show that as soon as the queue never empties, we have a very non-intuitive rate dynamic and that in partcular the ratio w(t)/rtt(t) is a constant. We test the analytical solution by comparison with NS2 simulation results.
Mots clés
Autre [cs.OH]
RR-4703.pdf (216.5 Ko) Télécharger le fichier
inria-00071883 , version 1 (23-05-2006)
  • HAL Id : inria-00071883 , version 1
Dohy Hong. A Note on the TCP Fluid Model. [Research Report] RR-4703, INRIA. 2003. ⟨inria-00071883⟩
68 Consultations
684 Téléchargements
