2D simulation of chemotactic bacteria aggregation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Americo Marrocco
  • Fonction : Auteur
  • PersonId : 833554
We start from a mathematical model which describes the collective motion of bacteria taking into account the underlying biochemistry. This model was first introduced by Keller-Segel . A new formulation of the system of partial differential equations is obtained by the introduction of a new variable (this new variable is similar to the quasi-Fermi level in the framework of semiconductor modelling). This new system of P.D.E. is approximat- ed via a mixed finite element technique. The solution algorithm is then described and finally we give some preliminary numerical results.Especially our method is well adapted to compute the concentration of bacteria.
Autre [cs.OH]
RR-4667.pdf (4.83 Mo) Télécharger le fichier
inria-00071918 , version 1 (23-05-2006)
  • HAL Id : inria-00071918 , version 1
Americo Marrocco. 2D simulation of chemotactic bacteria aggregation. [Research Report] RR-4667, INRIA. 2002. ⟨inria-00071918⟩
135 Consultations
356 Téléchargements
