The arithmetic of Jacobian groups of superelliptic cubics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We present two algorithms for the arithmetic of cubic curves with a totally ramified prime at infinity. The first algorithm, inspired by Cantor's reduction for hyperelliptic curves, is easily implemented with a few lines of code, making use of a polynomial arithmetic package. We prove explicit reducedness criteria for superelliptic curves of genus 3 and 4, which show the correctness of the algorithm. The second approach, quite general in nature and applicable to further classes of curves, uses the FGLM algorithm for switching between Gröbner bases for different orderings. Carrying out the computations symbolically, we obtain explicit reduction formulae in terms of the input data.
Autre [cs.OH]
RR-4618.pdf (340.79 Ko) Télécharger le fichier
inria-00071967 , version 1 (23-05-2006)
inria-00071967 , version 2 (30-10-2009)
  • HAL Id : inria-00071967 , version 1
Abdolali Basiri, Andreas Enge, Jean-Charles Faugère, Nicolas Gürel. The arithmetic of Jacobian groups of superelliptic cubics. [Research Report] RR-4618, 2002, pp.27. ⟨inria-00071967v1⟩
Collections
INRIA-RRRT
250 Consultations
397 Téléchargements
