Mixture of linear mixed models Application to repeated data clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
The problem of finite mixture analysis from repeated data is considered. Data variability is taken into account through linear mixed models leading to a mixture of mixed models. The maximum likelihood estimation of this family of models through the EM algorithm is presented. The problem of selecting a particular mixture of mixed models is considered. Illustrative Monte Carlo experiments are presented and an application to the clustering of gene expression profiles is detailed. All those experiments highlight the interest of linear mixed model mixtur es for taking account of data variability in a proper way.
RR-4566.pdf (253.59 Ko) Télécharger le fichier
inria-00072022 , version 1 (23-05-2006)
  • HAL Id : inria-00072022 , version 1
Gilles Celeux, Christian Lavergne, Olivier C. Martin. Mixture of linear mixed models Application to repeated data clustering. [Research Report] RR-4566, INRIA. 2002. ⟨inria-00072022⟩
144 Consultations
585 Téléchargements
