A Greedy Delaunay Based Surface Reconstruction Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
David Cohen-Steiner
  • Fonction : Auteur
  • PersonId : 833472
Frank Da
  • Fonction : Auteur
In this paper, we present a new greedy algorithm for surface reconstruction from unorganized point sets. Starting from a seed facet, a piecewise linear surface is grown by adding Delaunay triangles one by one. The most plausible triangles are added in the first place, in a way that prevents the appearance of topological singularities. The output is thus guaranteed to be a piecewise linear orientable manifold, possibly with boundary. Experiments show that this method is very fast, and achieves topologically correct reconstruction in most cases. Moreover, it can handle surfaces with complex topology, boundaries, and non uniform sampling.
Autre [cs.OH]
RR-4564.pdf (820.8 Ko) Télécharger le fichier
inria-00072024 , version 1 (23-05-2006)
  • HAL Id : inria-00072024 , version 1
David Cohen-Steiner, Frank Da. A Greedy Delaunay Based Surface Reconstruction Algorithm. RR-4564, INRIA. 2002. ⟨inria-00072024⟩
236 Consultations
2494 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
