Introduction to Logical Information Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Sébastien Ferré
Olivier Ridoux
Logical Information Systems (LIS) use logic in a uniform way to describe their contents, to query it, to navigate through it, to analyze it, and to maintain it. They can be given an abstract specification that does not depend on the choice of a particular logic, and concrete instances can be obtained by instantiating this specification with a particular logic. In fact, a logic plays in a LIS the role of a schema in data-bases. We present the principles of logical information systems, the constraints they impose on the expression of logics, and hints for their effective implementation.
RR-4540.pdf (416.1 Ko) Télécharger le fichier
inria-00072048 , version 1 (23-05-2006)
  • HAL Id : inria-00072048 , version 1
Sébastien Ferré, Olivier Ridoux. Introduction to Logical Information Systems. [Research Report] RR-4540, INRIA. 2002. ⟨inria-00072048⟩
83 Consultations
569 Téléchargements
