Computing multicast trees in dynamic networks using evolving graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
New technologies and the deployment of mobile and nomadic services are driving the emergence of complex communications networks, that have a highly dynamic behavior. This naturally engenders new route-discovery problems under changing conditions over these networks. Unfortunately, the temporal variations in the network topology are hard to be effectively captured in a classical graph model. In this paper, we use and extend a recently proposed graph theoretic model, which helps capture the evolving characteristi- c of such networks, in order to compute multicast trees with minimum overall transmission time for a class of wireless mobile dynamic networks. We first show that computing different types of strongly connected components in this model is NP-Complete, and then propose an algorithm to build all rooted directed minimum spanning trees in already identified strongly connected components.
RR-4531.pdf (269.81 Ko) Télécharger le fichier
inria-00072057 , version 1 (23-05-2006)
  • HAL Id : inria-00072057 , version 1
Sandeep Bhadra, Afonso Ferreira. Computing multicast trees in dynamic networks using evolving graphs. [Research Report] RR-4531, INRIA. 2002. ⟨inria-00072057⟩
205 Consultations
302 Téléchargements
