On the combinatorial complexity of Euclidean Voronoi cells and convex hulls of d-dimensional spheres - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Menelaos I. Karavelas
  • Fonction : Auteur
In this paper we show an equivalence relationship between additively weighted Voronoi cells in R [power d], power diagrams in R [power d] and convex hulls of spheres in R [power d]. An immediate consequence of this equivalence relationship is a tight bound on the complexity of : (1) a single additively weighted Voronoi cell in dimension d ; (2) the convex hull of a set of d-dimensional spheres. In particular, given a set of n spheres in dimension d, we show that the worst case complexity of both a single additively weighted Voronoi cell and the convex hull of the set of spheres is [THÊTA](n[power d/2]). The equivalence between additively weighted Voronoi cells and convex hulls of spheres permits us to compute a single additively weighted Voronoi cell in dimension d in worst case optimal time [OMICRON](n log n + n[power d/2]).
Autre [cs.OH]
RR-4504.pdf (146.5 Ko) Télécharger le fichier
inria-00072084 , version 1 (23-05-2006)
  • HAL Id : inria-00072084 , version 1
Jean-Daniel Boissonnat, Menelaos I. Karavelas. On the combinatorial complexity of Euclidean Voronoi cells and convex hulls of d-dimensional spheres. RR-4504, INRIA. 2002. ⟨inria-00072084⟩
465 Consultations
391 Téléchargements
