New two-dimensional slope limiters for discontinuous Galerkin methods on arbitrary meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
In this paper we introduce an extension of Van Leer's slope limiter for two-dimensional Discontinuous Galerkin (DG) methods on arbitrary unstructured quadrangular or triangular grids. The aim is to construct a non-oscillatory shock capturing DG method for the approximation of hyperbolic conservative laws without adding excessive numerical dispersion. Unlike some splitting techniques that are limited to linear approximations on rectangular grids, in this work, the solution is approximated by means of piecewise quadratic functions. The main idea of this new reconstructing and limiting technique follows a well-known approach where local maximum principle regions are defined by enforcing some constraints on the reconstruction of the solution. Numerical comparisons with some existing slope limiters on structured as well as on unstructured meshes show a superior accuracy of the proposed slope limiters.
RR-4491.pdf (1.95 Mo) Télécharger le fichier
inria-00072097 , version 1 (23-05-2006)
  • HAL Id : inria-00072097 , version 1
Hussein Hoteit, Philippe Ackerer, Robert Mosé, Jocelyne Erhel, Bernard Philippe. New two-dimensional slope limiters for discontinuous Galerkin methods on arbitrary meshes. [Research Report] RR-4491, INRIA. 2002. ⟨inria-00072097⟩
260 Consultations
1006 Téléchargements
