Random Walks and Chemical Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We consider continuous time random walks in the orthant with bounded jumps, the rates however are not bounded - they have a polynomial dependence on the coordinates of the point. The case when the rates are bounded correspon- ds in applications to the queueing theory, more exactly to markovian communication networks. The goal of this paper is to discuss the situation for polynomial rates, we show that the boundaries do not play role, but new effects and complicated behaviour can arise due to different time scales.
Autre [cs.OH]
RR-4412.pdf (215.77 Ko) Télécharger le fichier
inria-00072176 , version 1 (23-05-2006)
  • HAL Id : inria-00072176 , version 1
Vadim A. A. Malyshev, S. A. Pirogov, A. Rybko. Random Walks and Chemical Networks. [Research Report] RR-4412, INRIA. 2002. ⟨inria-00072176⟩
34 Consultations
140 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
