About the linear-quadratic regulator problem under a fractional Brownian perturbation and complete observation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
In this report we solve the basic fractional analogue of the classical linear-quadratic Gaussian regulator problem in continuous-time. For a completely observable controlled linear system driven by a fractional Brownian motion, we describe explicitely the optimal control policy which minimizes a quadratic performance criterion.
Autre [cs.OH]
RR-4358.pdf (229.35 Ko) Télécharger le fichier
inria-00072230 , version 1 (23-05-2006)
  • HAL Id : inria-00072230 , version 1
Marina Kleptsyna, Alain Le Breton, Michel Viot. About the linear-quadratic regulator problem under a fractional Brownian perturbation and complete observation. [Research Report] RR-4358, INRIA. 2002. ⟨inria-00072230⟩
107 Consultations
146 Téléchargements
