Ananas : A New Adhoc Network Architectural Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
In this paper, we present a new architecture for adhoc networks : Ananas. Based on the combined use of a classical adhoc routing protocol and virtual adhoc interfaces, Ananas allows a complete support for the IP protocol over adhoc networks, including auto-configuration mechanisms such as the IPv6 one or DHCP. It also provides Internet connectivity and compatibility with Internet services and protocols such as multicast. Finally Ananas addresses problems of scalability and adhoc network partitioning.
Autre [cs.OH]
RR-4354.pdf (259.29 Ko) Télécharger le fichier
inria-00072234 , version 1 (23-05-2006)
  • HAL Id : inria-00072234 , version 1
Guillaume Chelius, Eric Fleury. Ananas : A New Adhoc Network Architectural Scheme. [Research Report] RR-4354, INRIA. 2002. ⟨inria-00072234⟩
93 Consultations
194 Téléchargements
