Linear Control of Live Marked Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Given a linear constraint on the firing vectors of a live marked graph (bounded or unbounded) with uncontrollable / unobservable transitions, we apply linear programming techniques to compute the most liberal controller enforcing this constraint. In the special case of strongly connected live marked graphs, we compute further on the most liberal controller that keeps the marked graph live and enforces the constraint.
RR-4251.pdf (338.32 Ko) Télécharger le fichier
inria-00072337 , version 1 (23-05-2006)
  • HAL Id : inria-00072337 , version 1
Philippe Darondeau, Xiaolan Xie. Linear Control of Live Marked Graphs. [Research Report] RR-4251, INRIA. 2001, pp.24. ⟨inria-00072337⟩
92 Consultations
197 Téléchargements
