Multiplication by an Integer Constant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
We present and compare various algorithms, including a new one, allowing to perform multiplications by integer constants using elementary operations. Such algorithms are useful, as they occur in several problems, such as the Toom-Cook-like algorithms to multiply large multiple-precision integers, the approximate computation of consecutive values of a polynomial, and the generation of integer multiplications by compilers.
Autre [cs.OH]
RR-4192.pdf (170.85 Ko) Télécharger le fichier
inria-00072430 , version 1 (24-05-2006)
  • HAL Id : inria-00072430 , version 1
Vincent Lefèvre. Multiplication by an Integer Constant. [Research Report] RR-4192, INRIA. 2001. ⟨inria-00072430⟩
251 Consultations
1115 Téléchargements
