Rewriting for Cryptographic Protocol Verification - Extended Version - - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Thomas Genet
Francis Klay
  • Fonction : Auteur
  • PersonId : 756522
  • IdRef : 191770396
On a case study, we present a new approach for verifying cryptographic protocols, based on rewriting and on tree automata techniques. Protocols are operationally described using Term Rewriting Systems and the initial set of communication requests is described by a tree automaton. Starting from these two representations, we automatically compute an over-approximation of the set of exchanged messages (also recognized by a tree automaton). Then, proving classical properties like confidentiality or authentication can be done by automatically showing that the intersection between the approximation and a set of prohibited behaviors is the empty set. Furthermore, this method enjoys a simple and powerful way to describe intruder work, the ability to consider an unbounded number of parties, an unbounded number of interleaved sessions, and a theoretical property ensuring safeness of the approximation.
Autre [cs.OH]
RR-3921.pdf (415.1 Ko) Télécharger le fichier
inria-00072731 , version 1 (24-05-2006)
  • HAL Id : inria-00072731 , version 1
Thomas Genet, Francis Klay. Rewriting for Cryptographic Protocol Verification - Extended Version -. [Research Report] RR-3921, INRIA. 2000. ⟨inria-00072731⟩
112 Consultations
273 Téléchargements
