The Handling of Graphs on PC Clusters : A Coarse Grained Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
We study the relationship between the design and analysis of graph algorithms in the coarsed grained parallel models and the behavior of the resulting code on clusters. We conclude that the coarse grained multicomputer model (CGM) is well suited to design competitive algorithms, and that it is thereby now possible to aim to develop portable, predictable and efficient parallel code for graph problems on clusters.
Autre [cs.OH]
RR-3897.pdf (123.28 Ko) Télécharger le fichier
inria-00072757 , version 1 (24-05-2006)
  • HAL Id : inria-00072757 , version 1
Isabelle Guérin Lassous, Jens Gustedt, Michel Morvan. The Handling of Graphs on PC Clusters : A Coarse Grained Approach. [Research Report] RR-3897, INRIA. 2000. ⟨inria-00072757⟩
77 Consultations
78 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
