Synchronous Modeling and Asynchronous deployment of Mobile Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
We introduce the programming model consisting of pre-ordered transition systems (Spots) for modeling synchronous and asynchronous concurrent systems in the presence of mobility and of dynamicity. The model of Spots provides an operational and a denotational semantics to an expressive calculus of mobile processes. Encodings of related asynchronous, synchronous and functional calculi (Join, Fusion and \lambda) are provided. The data-structure of Spots is shown to have a canonical, hierarchic, representation. This representation is the basis for the decisions of key properties for a correct deployment of synchronous system specifications on asynchronous architecture. The property of endochrony (i.e.the equivalence between the synchronous (internal) and asynchronous (external) observation of a system) determines which components of a system can be compiled separately and executed autonomously; The property of isochrony (i.e.the equivalence between the synchronous and asynchronous compositions of endochronous components) determines which components of a system can be distributed over a network without loss of information.
Autre [cs.OH]
RR-3893.pdf (711.26 Ko) Télécharger le fichier
inria-00072761 , version 1 (24-05-2006)
  • HAL Id : inria-00072761 , version 1
Jean-Pierre Talpin. Synchronous Modeling and Asynchronous deployment of Mobile Processes. [Research Report] RR-3893, INRIA. 2000. ⟨inria-00072761⟩
106 Consultations
204 Téléchargements
