Ciphertext only Reconstruction of LFSR-based Stream Ciphers
Anne Canteaut 1 Eric Filiol 1
1 CODES - Coding and cryptography
Inria Paris-Rocquencourt
Abstract : This report presents an operational reconstruction technique of most stream ciphers. We primarily expose it for systems where several linear feedback shift registers (LFSR) are combined by a nonlinear Boolean function. With only short ciphertexts, it is shown how to completely recover the different feedback polynomials and the combining function, when the algorithm is totally unknown. Estimates of necessary cipherlength and experimental results are detailed.
Type de document :
Rapport
[Research Report] RR-3887, INRIA. 2000
Liste complète des métadonnées
https://hal.inria.fr/inria-00072766
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 10:50:41
Dernière modification le : vendredi 25 mai 2018 - 12:02:03
Document(s) archivé(s) le : dimanche 4 avril 2010 - 20:57:31
Fichiers
  • HAL Id : inria-00072766, version 1
Collections
Citation
Anne Canteaut, Eric Filiol. Ciphertext only Reconstruction of LFSR-based Stream Ciphers. [Research Report] RR-3887, INRIA. 2000. 〈inria-00072766〉
Métriques
Consultations de la notice
192
Téléchargements de fichiers
191
