Ciphertext only Reconstruction of LFSR-based Stream Ciphers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Anne Canteaut
Eric Filiol
  • Fonction : Auteur
  • PersonId : 833484
This report presents an operational reconstruction technique of most stream ciphers. We primarily expose it for systems where several linear feedback shift registers (LFSR) are combined by a nonlinear Boolean function. With only short ciphertexts, it is shown how to completely recover the different feedback polynomials and the combining function, when the algorithm is totally unknown. Estimates of necessary cipherlength and experimental results are detailed.
RR-3887.pdf (334.63 Ko) Télécharger le fichier
inria-00072766 , version 1 (24-05-2006)
  • HAL Id : inria-00072766 , version 1
Anne Canteaut, Eric Filiol. Ciphertext only Reconstruction of LFSR-based Stream Ciphers. [Research Report] RR-3887, INRIA. 2000. ⟨inria-00072766⟩
192 Consultations
558 Téléchargements
