High Frequency Limit of the Helmholtz Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
François Castella
  • Fonction : Auteur
  • PersonId : 828826
Thodoros Katsaounis
  • Fonction : Auteur
Benoît Perthame
We derive the high frequency limit of the Helmholtz equations in terms of quadratic observables. We prove that it can be written as a stationary Liouville equation with source terms. Our method is based on the Wigner Transform, which is a classical tool for evolution dispersive equations. We extend its use to the stationary case after an appropriate scaling of the Helmholtz equation. Several specific difficulties arise here; first, the identification of the source term (which does not share the quadratic aspect) in the limit, then, the lack of L2 bounds which can be handled with homogeneous Morrey-Campanato estimates, and finally the problem of uniqueness which, at several stage of the proof, is related to outgoing conditions at infinity.
Autre [cs.OH]
RR-3785.pdf (285.89 Ko) Télécharger le fichier
inria-00072875 , version 1 (24-05-2006)
  • HAL Id : inria-00072875 , version 1
Jean-David Benamou, François Castella, Thodoros Katsaounis, Benoît Perthame. High Frequency Limit of the Helmholtz Equations. [Research Report] RR-3785, INRIA. 1999. ⟨inria-00072875⟩
242 Consultations
246 Téléchargements
