A Component-Wise EM Algorithm for Mixtures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
In some situations, EM algorithm shows slow convergence problems. One possible reason is that standard procedures update the parameters simultaneous- ly. In this paper we focus on finite mixture estimation. In this framework, we propose a component-wise EM, which updates the parameters sequentially. We give an interpretation of this procedure as a proximal point algorithm and use it to prove the convergence. Illustrative numerical experiments show how our algorithm compares to EM and a version of the SAGE algorithm.
RR-3746.pdf (315.24 Ko) Télécharger le fichier
inria-00072916 , version 1 (24-05-2006)
  • HAL Id : inria-00072916 , version 1
Gilles Celeux, Stéphane Chrétien, Florence Forbes, Abdallah Mkhadri. A Component-Wise EM Algorithm for Mixtures. [Research Report] RR-3746, INRIA. 1999. ⟨inria-00072916⟩
108 Consultations
519 Téléchargements
