The Game of the Name in Cryptographic Tables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
Sanjiva Prasad
  • Fonction : Auteur
We present a name-passing calculus that can be regarded as a simplified pi-calculus equipped with a cryptographic table. The latter is a data structure representing the relationships among names. We apply the calculus to the modelling and verification of secrecy and authenticity properties in cryptographic protocols relying on symmetric shared keys. Following classical approaches [8], we formulate the verification task as a reachability problem and prove its decidability assuming finite principals and bounds on the sorts of the messages synthesized by the attacker.
Autre [cs.OH]
RR-3733.pdf (270.83 Ko) Télécharger le fichier
inria-00072932 , version 1 (24-05-2006)
  • HAL Id : inria-00072932 , version 1
Roberto M. Amadio, Sanjiva Prasad. The Game of the Name in Cryptographic Tables. RR-3733, INRIA. 1999. ⟨inria-00072932⟩
206 Consultations
170 Téléchargements
