Proof of the Subject Reduction Property for a Pi-Calculus in COQ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
This paper presents a method for coding pi-calculus in the COQ proof assistant- , in order to use this environment to formalize properties of the pi-calculus. This method consists in making a syntactic discrimination between free names (then called parameters) and bound names (then called variables) of the processes, so that implicit renamings of bound names are avoided in the substitution operation. This technique has been used by J.McKinna and R.Pollack in an extensive study of PTS [5]. We use this coding here to prove subject reduction property for a type system of a monadic pi-calculus.
Autre [cs.OH]
RR-3698.pdf (247.09 Ko) Télécharger le fichier
inria-00072970 , version 1 (24-05-2006)
  • HAL Id : inria-00072970 , version 1
Loïc Henry-Gréard. Proof of the Subject Reduction Property for a Pi-Calculus in COQ. RR-3698, INRIA. 1999. ⟨inria-00072970⟩
104 Consultations
205 Téléchargements
