Directed Virtual Path Layouts in ATM Networks
Motivated by Asynchronous Transfer Mode (ATM) in telecommunication networks, we investigate the problem of designing a directed virtual topology on a directed physical topology, which consists in finding a set of directed virtual paths (VPs) satisfying some constraints in terms of load (the number of VPs sharing a physical link) and hop count (the number of VPs used to establish a connection). For both general and particular networks, such as paths, cycles, meshes, tori and trees, we derive tight bounds on the virtual diameter (the maximum hop count for a connection) as a function of the network capacity (the maximum load of a physical link).
