Improving Data Freshness in Replicated Databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Esther Pacitti
Data replication is often used in distributed database applications to improve data availability and performance. Replicated data must be periodicall- y refreshed using update propagation strategies. Most of the current strategie- s guarantee mutual consistency of replicated data but are inefficient. Lazy (or asynchronous) replication is an alternative, more efficient solution where mutual consistency is relaxed. It is needed in applications such as on-line financial transactions and telecommunication systems which require high freshness of replicated data. In this case, the concept of \it freshness
Autre [cs.OH]
RR-3617.pdf (691.7 Ko) Télécharger le fichier
inria-00073061 , version 1 (24-05-2006)
  • HAL Id : inria-00073061 , version 1
Esther Pacitti. Improving Data Freshness in Replicated Databases. [Research Report] RR-3617, INRIA. 1999. ⟨inria-00073061⟩
92 Consultations
286 Téléchargements
