Automatic Differentiation for Adjoint Code Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
This document is a compilation of extended abstracts presented at the Automatic Differentiation session entitled «Automatic Differentiation for adjoint code generation» which has been held within the IMACS Conference on Applications of Computer Algebra held in Prague (Czech Republic) in August 1998. This is the second Automatic Differentiation session organized within IMACS'ACA conferences.
RR-3555.pdf (605.58 Ko) Télécharger le fichier
inria-00073128 , version 1 (24-05-2006)
  • HAL Id : inria-00073128 , version 1
Christèle Faure. Automatic Differentiation for Adjoint Code Generation. [Research Report] RR-3555, INRIA. 1998. ⟨inria-00073128⟩
62 Consultations
566 Téléchargements
