Analytic Variations on Redundancy Rates of Renewal Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Wojtek Szpankowski
  • Fonction : Auteur
Csiszár and Shields have recently proved that the minimax redundancy for a class of renewal processes is $\Theta(\sqrt{n})$ where $n$ is the block length. This interesting result provides a first non-trivial bound on redundancy for a non-parametric family of processes. The present paper provides a precise estimate up to the constant term of the redundancy rate for such sources. The asymptotic expansion is derived by complex--analytic methods that include generating function representations, Mellin ransforms, singularity analysis and saddle point estimates. This work places itself within the framework of analytic information theory.
RR-3553.pdf (388.27 Ko) Télécharger le fichier
inria-00073130 , version 1 (24-05-2006)
  • HAL Id : inria-00073130 , version 1
Philippe Flajolet, Wojtek Szpankowski. Analytic Variations on Redundancy Rates of Renewal Processes. [Research Report] RR-3553, INRIA. 1998. ⟨inria-00073130⟩
52 Consultations
144 Téléchargements
