Kalman Filtering for General Discrete-time Linear Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Recursive state estimation problems for explicit and implicit time-invariant linear systems, both for systems with and without unknown inputs, can be formulated as a single problem usually referred to as descriptor Kalman filtering. Solutions to this problem have been proposed in the literature, however, these solutions either neglect possible contributions of future dynamics to the current estimate or make unnecessary assumptions on the structure of the system. In this paper we propose a solution to this problem which leads to a constructive method lifting these unnecessary assumptions. This method uses a generalization of the shuffle algorithm.
Autre [cs.OH]
RR-3343.pdf (296.84 Ko) Télécharger le fichier
inria-00073346 , version 1 (24-05-2006)
  • HAL Id : inria-00073346 , version 1
Ramine Nikoukhah, Stephen L. Campbell, François Delebecque. Kalman Filtering for General Discrete-time Linear Systems. [Research Report] RR-3343, INRIA. 1998. ⟨inria-00073346⟩
55 Consultations
686 Téléchargements
