Dobrushin's Mean-Field Approximation for a Queue With Dynamic Routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
A queueing system is considered, with a large number $N$ of identical infinite-buffer FCFS single-servers. The system is fed by a Poisson flow of rate $\l N$, with i.i.d. service times, under the non-overload condition. Each arriving task joins a server by selecting it from an independently (and `completely randomly') chosen collection of $m\ll N$ servers, on the basis of some fixed dynamic routing policy. We discuss various properties of such a system as $N\to\infty$. In particular, a natural limiting random process describing statistical properties of the system turns out to be deterministic.
RR-3328.pdf (390.79 Ko) Télécharger le fichier
inria-00073361 , version 1 (24-05-2006)
  • HAL Id : inria-00073361 , version 1
Nikita D. Vvedenskaya, Yuri M. Suhov. Dobrushin's Mean-Field Approximation for a Queue With Dynamic Routing. [Research Report] RR-3328, INRIA. 1997. ⟨inria-00073361⟩
145 Consultations
353 Téléchargements
