A Critical Evaluation of the Classical $k-\varepsilon$ Model and Wall-Laws for Unsteady Flows over Bluff Bodies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
The classical $k-\varepsilon$ model and a new implementation of wall-laws have been evaluated for unsteady turbulent flows past square and circular cylinders. We show that good numerics can lead to a serious improvement of the results. In the case of the flow past a square cylinder (Lyn's test case), results agree surprisingly well with the experimental data. In the analysis of the vortex shedding flow past a circular cylinder also the agreement is quite good for the sub-critical regime but not entirely satisfactory after the critical Reynolds number (i.e. the drag crisis phenomenon
Mots clés
Autre [cs.OH]
RR-3056.pdf (1.49 Mo) Télécharger le fichier
inria-00073636 , version 1 (24-05-2006)
  • HAL Id : inria-00073636 , version 1
Bijan Mohammadi, Gorazd Medic. A Critical Evaluation of the Classical $k-\varepsilon$ Model and Wall-Laws for Unsteady Flows over Bluff Bodies. [Research Report] RR-3056, INRIA. 1996. ⟨inria-00073636⟩
64 Consultations
364 Téléchargements
