A region-level graph labeling approach to motion-based segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Marc Gelgon
Patrick Bouthemy
  • Fonction : Auteur
  • PersonId : 830256
This paper deals with the problem of motion-based segmentation of image sequences. Such partitions are multiple-purpose in dynamic scene analysis We first extract a texture-based partition using an unsupervised MRF approach. The regions obtained are then grouped according to a motion-based criterion. This grouping process relies on two motion estimation techniques and exploits contextual information between regions. In contrast with clustering techniques, region grouping is formalized as a motion-based graph labeling process, within a Markovian framework. Results on real-world image sequences are shown and validate the proposed method.
RR-3054.pdf (387.64 Ko) Télécharger le fichier
inria-00073638 , version 1 (24-05-2006)
  • HAL Id : inria-00073638 , version 1
Marc Gelgon, Patrick Bouthemy. A region-level graph labeling approach to motion-based segmentation. [Research Report] RR-3054, INRIA. 1996. ⟨inria-00073638⟩
105 Consultations
196 Téléchargements
