Definition of a 4D Continuous Polar Transformation for the Tracking and the Analysis of LV Motion - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports Year : 1996
Jacques Feldmar
  • Function : Author
Nicholas Ayache
Cardiologists assume that analysis of the motion of the heart (especially the left ventricle) can give precise information about the health of the myocardium. A 4D polar transformation is defined to describe the left ventricle (LV) motion and a method is presented to estimate it from sequences of 3D images. The transformation is defined in 3D-planispheric coordinates by a small number of parameters involved in a set of simple linear equations. It is continuous and regular in time and space, periodicity in time can be imposed. The local motion can be easily decomposed into a few canonical motions (centripetal contraction, rotation around the long-axis, elevation). To recover the motion from original data, the 4D polar transformation is calculated using an adaptation of the Iterative Closest Point algorithm. We present the mathematical framework and a demonstration of its feasability on a set of synthetic but realistic datapoints, simulating the motion of the LV and on a gated SPECT sequence.
Domains
Other [cs.OH]
RR-3039.pdf (647.42 Ko) Télécharger le fichier
Dates and versions
inria-00073654 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073654 , version 1
Cite
Jérôme Declerck, Jacques Feldmar, Nicholas Ayache. Definition of a 4D Continuous Polar Transformation for the Tracking and the Analysis of LV Motion. RR-3039, INRIA. 1996. ⟨inria-00073654⟩
108 View
231 Download
Share
