Functional Back-Ends within the Lambda-Sigma Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Thérèse Hardin
  • Fonction : Auteur
Luc Maranget
Bruno Pagano
  • Fonction : Auteur
We define a weak lambda-calculus, lambda-sigma-w, as a subsystem of the full lambda-calculus with explicit substitutions lambda-sigma-lift. We claim that lambda-sigma-w could be the archetypal output language of functional compilers, just as the lambda-calculus is their universal input language. Furthermore, lambda-sigma-lift could be the adequate theory to establish the correctness of simplified functional compilers. Here, we illustrate these claims by proving the correctness of four simplified compilers and runtime systems modeled as abstract machines. The four machines we prove are the Krivine machine, the SECD, the FAM and the CAM. Thereby, we give the first formal proofs of Cardelli's FAM and of its compiler.
RR-3034.pdf (518.23 Ko) Télécharger le fichier
inria-00073659 , version 1 (24-05-2006)
  • HAL Id : inria-00073659 , version 1
Thérèse Hardin, Luc Maranget, Bruno Pagano. Functional Back-Ends within the Lambda-Sigma Calculus. [Research Report] RR-3034, INRIA. 1996. ⟨inria-00073659⟩
118 Consultations
363 Téléchargements
