Proving Data-Parallel Programs : a Unifying Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
David Cachera
Gil Utard
We define an axiomatic semantics for a common kernel of existing data-parallel languages. We introduce an assertional language which enables us to define a weakest liberal precondition calculus which has the Definability Property, and a proof system ({\it à la\/} Hoare) which has the Completeness Property. Moreover, our axiomatic semantics integrates two previous works in the definition of proof systems for data-parallel programs. This work sheds a new light on the logical complexity of proving data-parallel programs.
RR-3032.pdf (335.42 Ko) Télécharger le fichier
inria-00073661 , version 1 (24-05-2006)
  • HAL Id : inria-00073661 , version 1
David Cachera, Gil Utard. Proving Data-Parallel Programs : a Unifying Approach. [Research Report] RR-3032, INRIA. 1996. ⟨inria-00073661⟩
66 Consultations
163 Téléchargements
