Boundary Control Problems for Shape Memory Alloys under State Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Nikolaus Bubner
  • Fonction : Auteur
Jürgen Sprekels
  • Fonction : Auteur
We consider two optimal control problems for first order martensitic phase transitions in a deformation--driven experiment on shape memory alloys including state constraints for the total stress and the temperature. We control by the elongation of a thin rod and by the outside temperature. The control problems are stated, and the necessary conditions of optimality are derived.
Autre [cs.OH]
RR-2994.pdf (231.61 Ko) Télécharger le fichier
inria-00073703 , version 1 (24-05-2006)
  • HAL Id : inria-00073703 , version 1
Nikolaus Bubner, Jan Sokolowski, Jürgen Sprekels. Boundary Control Problems for Shape Memory Alloys under State Constraints. [Research Report] RR-2994, INRIA. 1996, pp.12. ⟨inria-00073703⟩
135 Consultations
79 Téléchargements
