A linear Time Algorithm for the Generation of Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Laurent Alonso
  • Fonction : Auteur
  • PersonId : 830118
Jean-Luc Rémy
  • Fonction : Auteur
René Schott
  • Fonction : Auteur
We present a linear algorithm which generates randomly and with uniform probability many kinds of trees: binary trees, ternary trees, arbitrary trees, forests of $p$ $k$-ary trees, $\ldots$. The algorithm is based on the definition of generic trees which can be coded as words. These words, in turn, are generated in linear time.
Autre [cs.OH]
RR-2934.pdf (311.34 Ko) Télécharger le fichier
inria-00073765 , version 1 (24-05-2006)
  • HAL Id : inria-00073765 , version 1
Laurent Alonso, Jean-Luc Rémy, René Schott. A linear Time Algorithm for the Generation of Trees. [Research Report] RR-2934, INRIA. 1996. ⟨inria-00073765⟩
104 Consultations
269 Téléchargements
