Circuit-Switched Gossiping in the 3-Dimensional Torus Networks - Archive ouverte HAL Access content directly
Reports Year : 1996
Stéphane Pérennes
  • Function : Author
  • PersonId : 942945
In this paper we describe, in the case of short messages, an efficient gossiping algorithm for 3-dimensional torus networks (wrap-around or toroidal meshes) that uses synchronous circuit-switched routing. The algorithm is based on a recursive decomposition of a torus. The algorithm requires an optimal number of rounds and a quasi-optimal number of intermediate switch settings to gossip in an $7^i \times 7^i \times 7^i$ torus.
RR-2930.pdf (198.56 Ko) Télécharger le fichier
Dates and versions
inria-00073769 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073769 , version 1
Cite
Olivier Delmas, Stéphane Pérennes. Circuit-Switched Gossiping in the 3-Dimensional Torus Networks. RR-2930, INRIA. 1996. ⟨inria-00073769⟩
75 View
171 Download
Share
