Hamilton Circuits in the Directed Butterfly Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
Eric Darrot
  • Fonction : Auteur
Olivier Delmas
Stéphane Pérennes
  • Fonction : Auteur
  • PersonId : 942945
In this paper, we prove that the wrapped Butterfly digraph $\vec{{\cal WBF}}(d,n)$ of degree $d$ and dimension $n$ contains at least $d-1$ arc-disjoint Hamilton circuits, answering a conjecture of D. Barth. We also conjecture that $\vec{{\cal WBF}}(d,n)$ can be decomposed into $d$ Hamilton circuits, except for $d=2$ $n=2$, $d=2$ $n=3$ and $d=3$ $n=2$ . We show that it suffices to prove the conjecture for $d$ prime and $n=3D2$. Then, we give such a Hamilton decomposition for all primes less than 12000 by a clever computer search, and so, as corollary, we have a Hamilton decomposition of $\vec{{\cal WBF}}(d,n)$ for any $d$ divisible by a number $q$, with $4 \leq q \leq 12000$.
RR-2925.pdf (214.58 Ko) Télécharger le fichier
inria-00073773 , version 1 (24-05-2006)
  • HAL Id : inria-00073773 , version 1
Jean-Claude Bermond, Eric Darrot, Olivier Delmas, Stéphane Pérennes. Hamilton Circuits in the Directed Butterfly Network. RR-2925, INRIA. 1996. ⟨inria-00073773⟩
111 Consultations
218 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
